orders_Update.php spry validation on fields?
Thread began 10/03/2009 3:13 am by uberbean | Last modified 10/05/2009 1:16 pm by Eric Mittman | 966 views | 1 replies |
msjj000Beta Tester
Hi WA,
I know you removed this on PowerStore2 however it is asking to change the number format on the bottom two fields - shipping telephone & shipping fax. the fields had numbers entered in the format as +xx x xxxx xxxx and the field requires x (xxx) xxx-xxxx
As a result it won't allow an update the the shipped status and also the shipped confirmation can't be sent as a result
The URL is orders_Update.php?valid=false&OrderID=1069
Note sure what I changed as there was no validation prior on these fields? I can find the specific lines with the"xx" format and change it however how do you turn the validation off or change/remove it?
Thanks, Mark.
If it is a Spry validation that is applied to the element then you should be able to select the element and see a bluish colored tab around the element. If you click on this tab it should bring up the properties for it in the property manager. You can adjust the formatting or the other values. You could remove this validation from the page completely by removing the event that triggers the validation and also removing it's Spry line of code in the page.
If it is a server side validation then you can remove it by editing the server validations entry in the server behaviors tab.
