LogOut
Thread began 10/02/2009 1:13 pm by jshaullmii377475 | Last modified 10/02/2009 4:02 pm by Jason Byrnes | 1872 views | 2 replies |
jshaullmii377475
LogOut
I have installed security assist and getting things working. One Item that does not seem to work is the logout. I went through the wizard and after that added a link to my front page to login. then I wrapped that link with your show/hide server behavior.
<?php if(WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<p class="welcome">
<?php echo "|".$_SESSION['miiusername']."|";?> <a class="prepend-1" href="users_LogOut.php" title="Logout">Logout</a>
</p>
<?php } // End Show Region ?>
<?php if(!WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<p class="welcome">
<a href="users_LogIn.php" title="Login">Login</a> | <a href="users_Registration.php" title="Login">Register</a> | <a href="cart.php" title="Viewcart">View Cart</a>
</p>
When I go to the page it show the appropriate link to login. Then when I log out it does not log out.....
Am I missing something in the code of the logout page?
tom92909Beta Tester
Try adding this to the top of your logout page...
session_start
session_destroy();
The log out page created by SecurityAssist uses the Clear Session Value server behavior from Cookies Toolkit. If Cookies toolkit is not installed when you run the SecurityAssist wizard, the log out page will not be created properly.
Once you have installed Cookies Toolkit, open the log out page. Go to the server behaviors panel and click the plus button. Select WA Cookies -> Clear Session value. Set it to Clear all and set the trigger to before page loads.
