Sculptor only for DW 9+
I tried to install Sculptor extension and got an error msg that says I have to be on DW 9 or above. I'm using DW 8.
1.) Is this correct and a requirement?
2.) What other products in the Extensions Library also require DW 9 and above?
The reason I'm asking is because I'm trying to use the templates in the library and it needs the Sculptor. Well is can be used with the sculptor.
Is there any info on how to implement the design templates? Can find any except for the readme file in the zip.
Terry
