Client Validation bug
Thread began 10/02/2009 3:24 am by rob75685 | Last modified 10/02/2009 10:44 am by Jason Byrnes | 1179 views | 1 replies |
rob75685
hi there
I have discovered a bug with CSS Form Builder's Client Validation Wizard.
I have a standard form that I created without CSS Form Builder.
The first few fields are:
firstname
surname
email
confirmemail
address
etc
etc
I then set up my Client Validation, checking that the firstname and surname are required, then a valid email, then checking that the field confirmemail is 'like' the email field.
Then I finish.
I look at my code and for the 'like' validation it's checking the field 'firstname' instead of email.
I go back to my Client Validation wizard and it has changed my 'like' validation to the wrong field.
So I change it back to 'email', and finish.
And it puts it back to 'firstname' again...
The only way I can change it is to manually edit the code, every time I open the Client Validation panel it changes the value back to the wrong field.
The only thing I can think of to rectify this is to make sure that my 'like' field is the first one
I have created a support ticket so we can look into this problem with you. To view and edit your support ticket, please log into your support history:
