Embedding a login section on a template from User Registration Solution Pack
Thread began 10/01/2009 4:23 pm by Doyleja368034 | Last modified 10/02/2009 3:32 pm by Doyleja368034 | 1720 views | 2 replies |
Doyleja368034
I want to have a small login form on all my pages (from a Template) in my left hand column which will work with the User Registration Solution Pack. Every time I try to insert the code from the users_LogIn page into the column, things just “spread out“ over the whole content area. And I can't seem to get this "idea" to work.
Any suggestions as to how I can implement this feature would be appreciated.
In your template you only need to add a form that contains a Text Box named "username" another named "userpassword" and an Image form element named "LogIn" Go to Insert -> Form -> Image Field to add an image field.
Set the action of the form to post to the users_LogIn.php page.
Doyleja368034
Thanking you
Thanks Jason, I know there had to be an easy way to do it!
Cheers
