about last 5 operations in admin area ?
Thread began 10/01/2009 3:25 pm by mehd389652 | Last modified 10/01/2009 4:19 pm by mikeybabe | 1639 views | 2 replies |
mehd389652
Is there a way of getting rid of these or turning them off
as they really serve no purpose other than balancing the
look of the design in CMS100. They take up space and are
annoying
I realize that their purpose is to keep track of what you
have done kind of like a running history but it's a feature
that I wouldn't use.
Now that I have CMS100 working beautiful I would like to
tweak it if I can to suit the way I work. I do like it's simplicity
and I can certainly see it's potential
It doesn't look to be a CMS that can be managed by an administrator ?
More or less it is a stand alone CMS that you set up and hand over to
a client. Would I be right in saying that ?
If you dont want it in the layout, yo can simply remove it from the page using Dreamweaver.
You will need to modify the css to adjust the layout of other components on the page to use the real estate that will be made available by removing that content.
Yes, you are correct in stating that it is a site you set up, then hand over to the client.
Where you state that the Last 5 changes may be a feature you wouldn't use, the client may find it useful to have the ability to roll the page back if they make a change that breaks something
mikeybabe
Thank you for your response
I see.
I'm still getting my head around modifying it all
but I can see it's potential and I like the interface
Mike
