Duplicating CSS Presets
Thread began 10/01/2009 3:22 pm by tim383164 | Last modified 10/05/2009 11:58 am by Dani Chankhour | 1918 views | 3 replies |
tim383164
Under CSS Sculptor 2 and the older Preset Manager environment, I used to take a pre-existing template say for example: "2 Column Fixed, Left Sidebar"
I would Highlight this preset, hit the Duplicate button and it would then create: "2 Column Fixed, Left Sidebar Copy"
I would then edit this copy and would be able to change the name of the preset at some point
Now with CSS Sculptor 3, this is not the case. It seems to only duplicate the colour scheme ie: Pacifica etc
So I clicked on Duplicate, and then in the next dialog box (where you select the colour preset) I clicked on the Help button, This brought up the help information referencing how the old CSS 2 Sculptor worked.
I need to be able to duplicate the whole Layout not just a colour preset.
Can someone show how this is done under the new CSS Sculptor 3 environment.
By the way I uninstalled all previous versions of CSS 2, Site Assist Pro 1.0.6 etc before installing the latest versions.
Dani Chankhour
If you wanted to duplicate the entire preset, after clicking the duplicate button you can selected all the colors in the list and click ok this will generate a new preset with all the 12 color schemes.
tim383164
Ok I have now tried that and it works as you have indicated.
So the next question is how do you rename the Copy of the full Preset template?
Dani Chankhour
There is no functionality to be able to rename the entire preset.
The only place you would be able to rename a preset individually is in the wizard when it asks you if you want to save the preset as a new preset.
