Error in activation
I have this error:
Hi, I just responded to your previous post. It seems that you are getting the error with all of our extension. I would definitely try renaming your configuration folder as i suggested in the previous post. If you still encounter the same issue, could you please tell me what version of DW you are using and the platform?
Now everything worked. Thank
