Membership discounts on selected products
Thread began 9/30/2009 7:11 am by john275907 | Last modified 9/30/2009 7:18 pm by john275907 | 1055 views | 4 replies |
john275907
I have a situation where members may purchase products and receive a discount. Each product may have its own discount rate for members and the rate is stored in the product table. So, to get the discount, the member must login and I need to show the discount when a product is added to the cart and also display it in the cart and checkout pages.
I cant seem to figure out how to use the Discount feature of the eCart Object wizard to provide this capability. Is this achievable using the wizard or must I use custom coding ?
Thanks.
mywebassist220499
You might consider adding some custom code to the actual product list or detail pages that does something like:
If (some session variable you get / create when the customer logs in exists) Then
price = regular price * rate
else
If you do this, you can show the discount with the product information, and, you can also store the price (regular or discount) when the customer adds the item to their cart.
Doing this shows the discount in the individual item price in the cart display as opposed to as a discount below the subtotal.
This approach might be easier than trying to create discount rules in the cart behavior.
Another variation on that suggestion would be to have an extra price column in the cart for the discounted members. You can then just bind this value to the other column and use the calculations to use one price over the other. This way would also show on a per item basis rather than all at the bottom but the benefit would be that the user can login after adding items to the cart to still get the discount rather than adjusting the price that is added to the cart if a member is logged in.
moniquenw362187
I believe I had the same issue John. The way i solved it (and this solution is posted somewhere here on these forums, but you'll have to dig):
In the triggers section add the following 2 triggers:
1. "Based on session variable value"--
If the value of the session variable VisitorIsMember is = a value of 1. (where VisitorIsMember is the name of my variable that determines valid membership upon login)
AND
2. "Number of items with a specific column value"--
If the total number of items where CatID has a value of 12 is > a value of 0. (where CatID=12, in my case, is all products that fall in the Training Manuals category)
Then in the calculations section use "based on items with a specific value":
total of Totalprice Where CatID has a value of 12 [times] 0.10
(depending on your discount, the '0.10' value will vary. In my case it's actually 0.1739, because members get $20 off the full price $115)
Hope this helps.
john275907
Many thanks to all who offered suggestions. It has certainly helped a lot. Will report back when I have a working solution.
