Process orders via email without Payment G8Way
OK - I was looking thru the forum for hints on how to setup eCart to process orders without a Payment gateway. Found some good posts and also discovered the post about the 4.5.1 dot release. Installed that and started to work thru the suggested process of using the Checkout Wizard and selecting PayPal Payments Pro then start making the required edits.
Thing is, I cant get thru the wizard. I have done this same thing 12 months ago on another project and with an earlier version of eCart - No probs - but did it the hard way.
Right now though, I have copied the same order summary and details tables from the previous project and when I get to the point in the wizard where I need to select the orders summary table the Table field and ID field in the wizard are greyed out indicating that there are no tables available. The correct Connection is displayed though.
My tables are called orderdetails_det, orders_ord and orderstatus_sta. I seem to recall reading somewhere else that table names with an underscore may be a problem. Anyone got any suggestions ?
Many thanks.
