Latest dot release causes a js error
see attached screenshot, this references a non existent line in the file mentioned
as advised in another thread I have installed the latest eCart dot release and this seem to have solved the problem
Thanks for the update Dave.
Next time make sure you list the steps you're taking to get the error so it'll be easier to identify the issue. Also its an eCart issue, so the post should be in that forum.
