Gateaway payments
Thread began 9/28/2009 10:40 am by info323054 | Last modified 9/29/2009 10:25 am by Jason Byrnes | 1007 views | 3 replies |
info323054
Gateaway payments
I am from Spain. I want the payments of my website to be processed at my bank remotely through the most common credit cards and also via PayPal.
I am using the Wizard of eCart, but can only ready as gateaways 2Checkout, Authorize.net, eWay etc. Since my website is to work through an Spanish bank, how shall I make the checkout pages etc.?
Thank you for your help.
Israel Paya.
You will need to hand code the checkout process to process payments through a gateway that is not available in eCart.
info323054
Thank you
Many thanks for your reply. Do you know what kind of hand code I have to write? Can I use the wizard and then delete some of the code generated in order to write mine in hand?
You would need to look through the API documentation from the gateway you wish to use for examples of the code to write.
The code for processing the transaction is added to the confirm page by the wizard, you could remove that code and replace with your code.
