Problem when inserting a Bracket? | into a update form
Thread began 9/27/2009 7:30 pm by dave315749 | Last modified 3/02/2010 9:48 pm by jade.burnside372067 | 2746 views | 8 replies |
dave315749
Weird problem,
I build backends for people with the data assist wizard, and i make text areas for them to type in meta descriptions for title tags keywords and descriptions..
The weird part is when i use a i think its called a upright bracket? "|" without the quotes of course it deletes everything after the | and puts it to the text area or field below and then deletes the next box and puts the data after that... heres a example
meta title : Web design | Website design | Search engine tags
meta: description: text here
meta: keywords: text here
but it ends up like this
meta title: web design
meta description: website design
meta keywords: search engine tags
Why would this be? and how can i get it to save the correct data right into one field called the meta title field?
Office-172461
That's actually the pipe character - used to "pipe" output somewhere other than the default output. Not sure how to solve your issue.
In the insert and update record, use the str_replace function to convert the pipe to the html entity. When you bind the meta title column to the input text box, the code will look like:
<?php echo ((isset($_POST["formElemenet"]))?$_POST["formElemenet"]:""); ?>
change that to:
<?php echo ((isset($_POST["formElemenet"]))?str_replace("|", "&#x7c;", $_POST["formElemenet"]):""); ?>
this will convert the "|" symbol to the html entity "&#x7c;"
dave315749
didnt work
It still moves any text after the Pipe to the next field when updating the record.
What else do you think it could be?
You need to perform the same conversion to the HTML entity in the update record server behavior just link in the insert record server behavior.
dave315749
Got it to work but still doesnt resolve the issue
Got it to work... but it shows up on the site as that html code, not | when i look at the source code.
What other work around is there? Is this a my sql problem? what else can i search for?
The problem is that we use the Pipe character as a column separator in the insert and update code. To use a pipe character, you will need to convert it to the html entity.There should be no problem in the display of your page if it is output as a the HTML entity.
dave315749
well its not the display, its for search engines to see in the title tags.. so i guess if there is no way there is no way. thanks!
jade.burnside372067
I found the same problem when I added fields for META data.
I solved it by replacing the | pipe | character as a delimiter and changing it to the ~ tilde~ character.
Of course, the same problem would arise if I wanted to use the tilde, but it's less likely that will be necessary.
Cheers.
