clear session variable when clear cart button is pressed
How can i clear my coupon session variable when the clear cart button is pressed?
Use the Cookie Toolkit clear Session Variable server behavior. For the trigger, select the Clear Caret button, in the list of session variables to clear, select the coupon code session variable.
