Syntax error after doing coupon tutorial
Hello, I have done the tutorial located here & read the forum. It was easy to follow but I'm getting this syntax on my cart page.
Here is some of the code I think youll need to see, including line 13, & I can see that line 10 is incorrect in the way it's been inserted(no space between php tag & <waecdeletetemp>) I have changed it, but thought you will want to see what the wysiwyg is doing.
//MX Widgets3 include
require_once('includes/wdg/WDG.php');
<waecdeletetemp>?>
if((((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") != "")) {
$_SESSION["PromoCode"] = "".((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") ."";
<?php<waecdeletetemp>
$cartOnlineMC->GetContent();
What is going on? I'm positive I've done it right, & I was only starting here to learn the technique, so I can move on to a dynamic discounts system that I have in the DB
Thanks for any help. Chris
