Continue Shopping & Checkout Buttons Not Working
Thread began 9/26/2009 8:53 pm by beyondconcepts256352 | Last modified 4/02/2010 4:16 pm by Jason Byrnes | 987 views | 3 replies |
I am redoing a site because eCart 4 won't work with eCart 3. So completely redo the shopping cart and payment pages, and now the "Continue Shopping" and "Checkout" redirect buttons won't work. I have set the behavior each time with no success.
I am running a Windows Server and asp script.
These buttons worked find in the eCart 3.
Please help...the client is really upset that the site is not working.
The code is live on the following URL
shoppingcart.asp
Perhaps there is a PHP error occurring on the page which is causing the redirect to fail.
To find out ad the following code at line 1:
error_reporting
(E_ALL);
if your still having problems, send a copy of the shopping cart page so I can look at the code.
Buttons Not Redirecting
Your last message you asked me to send the code. It has been some time with the request as the client asked to stop work on the site, not knowing if they wanted to keep it going...well now they do.
I have attached a zip files of the shopping cart process.
All of the "add to cart" buttons are redirecting to a virtual directory. I am thinking that this might be causing the problem.
The website address is
www.copperscapes.com/
I look forward to hearing from you.
Thank you,
Joel
CopperScapesWA_eCart.zip
CopperScapesshoppingcart.zip
login.php
