Wizard crasched DW
Thread began 9/26/2009 2:24 am by olle189996 | Last modified 9/28/2009 2:00 pm by olle189996 | 2018 views | 5 replies |
olle189996
Wizard crasched DW
Hi
When running Wizard DW crashes with no warning. Just after the Results page have been created.
I managed to get it working again by renaming the configuration folder.
I wonder if its any simpler way than replacing the whole config folder? I had so many preferences and extensions installed that are now gone :(
I'm on a Mac G5, 10.5.6, And the latest of WA extensions an DWCS4.
The latest I did before DataAssist problems was to install latest update of CSS Menu writer.
Regards
Olle
office172461
I don't do Mac but you might find some help here:
Solving problems with Dreamweaver
146/
olle189996
Thank you. But i have seen that.
The question I had was if there is any other method that could help. Instead of deleting the config folder.
Well ...
regards
olle
Office-172461
I was referring to the Adobe troubleshooting document.
When you install updates, make sure to remove the previous version of the extension before installing the updated version.
After the update has been installed, you should delete the Dreamweaver cache file from the users configuration folder:
olle189996
Thanks but no :(
I reinstalled all Webassist extensions and trashed the cache file.
running Dataassist still crashes DW just after creating the results page. I tried 2 different sites.
Well, I'll just have to go for the new config folder then ...
regards
olle
