IE8 Issues
Thread began 9/25/2009 11:29 pm by Suggs | Last modified 9/26/2009 12:52 pm by Reynold | 1458 views | 1 replies |
Suggs
IE8 Issues
Hi Folks,
Ive builtmy site using CSS Sculptor 2 (and ive now gone on to purchase version 3 as well), however when it shows in IE8, it appears broken. In order to fix it and make it render correctly, I have to have the IE8 compatibility mode switched on in the browser.
Is there and IE fix I can use to correct this as it is happening on non data driven and data driven pages.
Paul
Reynold
Clear Float
Yeah, its a well known problem with IE 8. Try reading this article - easyclearing.html
I just embed the clear float into the style sheet and it works.
Not a problem, if you know how. This is a problem when using automatated tool like the extensions.
Hope this helps out!
