Values being Passed from submit button
I am using the dynamic dropdowns and it is doing exactly as I needed, but with one small issue. I have three boxes and have created id's in three different tables. The lists I have consist of: Region, Building, and Project.
The problem I am having is not when the boxes load, those are loading with the text values from the DB like it is supposed to. However, when I submit the page the id's are being passed instead of the list values. This is being passed into Crystal and it works when I select one field,but once I select more than one it tries to pass as a string.
Instead what I want is for it to pass the values. I can see in the array option [0] as the id and [1] as the value, but where do I specify in the code to pass [1] instead of [0], or the values instead of the id's? I followed the instructions to a tee and very easy, but cannot figure out which control changes this part.
Any help would be greatly appreciated. I have attached the could for you to look at.
Here is the web link with response.write in the setSelectionInformation () fiunction. When you select items it will give an error, but also display the values's for the objects you selected. I need this to be the text from the lists instead of the id's.
Just select Americas | 100 Summer Street | then the two Projects and hit run report.
Finance_Details.asp
Thank you in advance!
