Syntax has me baffled
Thread began 9/24/2009 11:18 pm by tom92909 | Last modified 9/25/2009 3:43 pm by Jason Byrnes | 1794 views | 6 replies |
tom92909Beta Tester
I need to run two numeric variables through a series "IF statements"...??? Unless there's a better way...
Here are my parameters... ( I do realize that what I'm typing in the code below is in NO WAY proper syntax, I'm just trying to ensure that I'm explaining myself clearly)
IF $x is even
   AND $y is even  ( do nothing)
IF $x is odd
   AND $y is odd  ( do nothing)
IF $x is even
   AND $y is odd  ( $y = $y+1)
IF $x is odd
   AND $y is even  ( $y = $y+1)
I've run into a wall here and need a helping hand.
Thanks!
Tom
anonymous
Tom,
You could either do a modified if statement or a case and switch statement. I think since two of your if statements should result in the same action, you would be best with a modified if statement like this:
if (($x%2=0 AND $y%2=0) OR ($x%2!=0 AND $y%2!=0)) {
DO NOTHING
} elseif (($x%2=0 AND $y%2!=0) OR ($x%2!=0 AND $y%2=0)) {
GO CRAZY
tom92909Beta Tester
hmmm, I'm not getting a positive result with that either.
$min
=5;
$max =12;
if ((
$min %AND $max %0) OR ($min %!= AND $max %!= 0)) {
} elseif ((
$min %AND $max %!= 0) OR ($min %!=AND $max %0)) {
$max $max+1;
echo
"$min";
echo
"$max";
The above code produces the following error...
  Parse error: syntax error, unexpected '=' on line 3
The following code will produce an echo result of "3 is odd"
$i
=3;
if (
$i 2) {
echo
"$i is odd";
} else {
echo
"$i is even";
So I'm still baffled on syntax...
tom92909Beta Tester
PHP makes efficient work out of my problem.
if($x%2 != $y%2) {
$y++;
Crazy simple solution. Cheers to PHP!
The error you where getting was because og the way you where doing the comparisons.
in this line:
if (($min %2 = 0 AND $max %2 = 0) OR ($min %2 != 0 AND $max %2 != 0)) {
this code is setting the result:
$min %2 = 0
to do an equals comparison in PHP, it should be:
$min %2 == 0
so that line should be:
if (($min %2 == 0 AND $max %2 == 0) OR ($min %2 != 0 AND $max %2 != 0)) {
tom92909Beta Tester
Jason,
Thanks for the clarification, that kinda helped, but I'm not really getting the output I wanted.
Let me explain again what I'm needing.
I have (2) dynamic numbers.
$x = 5;
$y = 14;
so my issue is how do I check for the following conditions...
IF $x < 0 ($x=0)
IF $x is even
IF $x < 0 ($x=0)
IF $x is odd
IF $x < 0 ($x=0)
IF $x is even
AND $y is odd ( $y++)
IF $x < 0 ($x=0)
IF $x is odd
AND $y is even ( $y++)
I'm a bit lost how to write the statement to get the above.
I hope that I've explained myself better this time.
try the following:
if($x < 0) $x = 0;
if (($x%2==0 AND $y%2!=0) OR ($x%2!=0 AND $y%2==0)) $y++;
If that does not give the desired results, please explain what the outcome is and how it differs from what you are trying to accomplish.
