Can I use CSS Sculptor to redirect mobile devices since I have flash?
Thread began 9/24/2009 12:45 pm by chris384639 | Last modified 9/24/2009 10:15 pm by chris384639 | 2826 views | 4 replies |
chris384639
I don't even know if this is the appropriate place to post this.
I have flash on each page... I'd like to have a CSS redirect or whatever it does to offer an alternative.
Suggestions?
Justin Nemeth
You would use JavaScript to detect the browser/mobile platform and redirect accordingly.
chris384639
Isn't there a JS alternative? I heard there is a CSS alternative, but I don't understand how that would fix the issue. Does it redirect to a new page or does the CSS block the flash and replace it with something else?
Justin Nemeth
CSS can't redirect the page, but you could make stylesheets that works only for mobile. Then in that CSS you could just hide the area containing the flash. You need to do JavaScript to redirect the page.
I've never targeted a mobile device myself, but you can probably just use the 'handheld' media type when including your CSS. Check out this page: css_mediatypes.asp
chris384639
Thanks Justin!
