digital file Pro
Thread began 9/24/2009 11:17 am by info379318 | Last modified 9/29/2009 3:06 pm by PeterL | 2005 views | 8 replies |
info379318
digital file Pro
I have used DFP several times without any trouble.
Now, i try to apply this extension and time after time i have the same problem;
I recieve the email correctly en the file is uploaded to the server but in the email i get the next weird code/text:
--WAMULTIBREAKWA
Content-Type: text/plain
Content-Transfer-Encoding: 8bit
--WAMULTIBREAKWA
Content-Type: application/octet-stream; name="scheiding-bergruimte.jpg"
Content-Transfer-Encoding: base64
Content-Disposition: inline; filename="scheiding-bergruimte.jpg"
anybody any idear?
Thanks, Peter
See the Known Issues section of the Universal Email download page. There is a fix there for this problem.
PeterL
Wa.ue
unfortunately in my case the replacement of the WAUniversalEmail.xml did not solve the problem. Don't remember if i had an update lately but i never had this problem so far!
I work on Mac Leopard Snow 10.6.1 and the server is Linux.
Send you the text i recieved from server:
--WAMULTIBREAKWA
Naam: Peter
Email: info@noordzuidweb.be
Onderwerp: verslag
Verzend: Verzend
--WAMULTIBREAKWA
Content-Type: application/octet-stream; name="bevestiging gesprek gemeente Eersel.doc"
Content-Disposition: inline; filename="bevestiging gesprek gemeente Eersel.doc"
0M8R4KGxGuEAAAAAAAAAAAAAAAAAAAAAPgADAP7/CQAGAAAAAAAAAAAAAAABAAAAKwAAAAAAAAAA
EAAALQAAAAEAAAD+////AAAAACoAAAD/////////////////////////////////////////////
///////////////////////////////////////////////////////////////////////////s
pcEAgYAJBAAA8BK/AAAAAAABEQABAAEACAAAHgwAAA4AYmpiaq71rvUAAAAAAAAAAAAAAAAAAAAA
etc. etc.
I had a case not to long ago where somebody had an issue with getting the xml file to stick. They had to try about 5 times before it worked, not sure why.
Try this:
Go to Window -> Workspace Layouts -> Reset '<layout name>'
Close Dreamweaver, then delete the Dreamweaver cache from the users configuration folder:
Then copy the xml file from the known issues pack again.
If it still doesn't fix the issue:
in the WA_UniversalEmail/mail_PHP.php file, find the following line:
$lineEnd = "\r\n";
and change it to:
$lineEnd = "\n";
PeterL
WA UE and DFP
Hello Jason,
your firts suggestion did'n solve the problem.(didn't try it 5 times)
About your next suggestion; can't find the code you mentioned.
(The problem does not occur in webmail!?)
Further there is in my opinium no serverproblem; on the url: insturen.php
everything works fine.
Here is the code in my php-file:
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "upload/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Verzend"])){
WA_DFP_UploadFiles("WA_UploadResult1", "Verslag", "0", "", "false", $WA_UploadResult1_Params);
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if ((isset($_POST["Verzend"]))) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "info@noordzuidweb.be";include("WA_Universal_Email/WAUE_links_4.php");
//Send Mail All Entries
if ("antwoord.html"!="") {
header("Location: antwoord.html");
Look in the WA_UniversalEmail/mail_PHP.php file.
It will be around line 114.
PeterL
Hello Jason,
Yes, changing the code was the solution.
However I doe not understand why this problem occurs; do I have to change the code in mail_php from now on every time i use UniversalEmail?
Peter
The xml file in the Known issues pack should change that for you. I cannot say why it is not working. If it is not working for you, you will need to make that change manually until the next universal Email update is released.
PeterL
Jason, I can live with that; replacement of the xml-file did not help in my case.
Thanks for your patience!
Peter
