Surveyor
Thread began 9/24/2009 5:14 am by martin317528 | Last modified 9/28/2009 7:30 pm by Eric Mittman | 3124 views | 7 replies |
martin317528
Surveyor
I'm getting the following error message when trying to use Surveyor:
While executing onResize in WA_SiteTools_Progress.htm, the following JavaScript error(s) occured: In file "WA_SiteTools_Progress": refreshUl is not defined.
Any ideas?
Have you tried deleting the cache file to see if it resolves the issue for you? Here is a link to a thread that discusses removing this file to fix issues:
showthread.php?t=1589
If this does not work for you please post back and let us know the version of DW you are working with and the OS. There is a known issue with this tool in DW8 build 3453 that prevents the floater from loading correctly and will result in a similar error.
martin317528
I should have tried that. Works a treat. Good for the Forum though. Thanks
Glad to hear that, it is always a good thing to try if you get some unexpected error when using the tool.
office172461
Solving problems with Dreamweaver
Hey Eric,
I put all the troubleshooting stuff into one article here to make it easier:
146/
Let me know if you have anything I should add or correct. I don't do Mac so if anyone sees any errors, let me know.
Nice Reference
That is a very clean troubleshooting doc, thanks for having it available like that. I'm sure many users will benefit from it directly, I know I have already bookmarked it myself. Thanks again.
office172461
Thanks Eric,
You inspired me to clean it up a little more. If you have any more general troubleshooting tips, I can add them to the bottom.
You seem to have some very good info in here, I have found myself handing out this link on a couple of occasions now and will probably be doing that more often. I will definitely let you know if I think of something that would be good for you to add to this.
