Mysqli no longer works on php 8.1.19
Thread began 5/19/2023 7:11 pm by anonymous | Last modified 5/22/2023 10:56 am by Ray Borduin | 141 views | 1 replies |
anonymous
Hi, having some trouble with getting MySQLi working on a more current version of php, specifically 8.1.19
Some troubleshooting steps:
1) Removed, downloaded and reinstalled the latest version of the Webassist components:
rsobj.php version 2.55
queryobj.php version 2.34
authentication.php version 2.22
2) Checked webserver log, produces the following error:
PHP Fatal error: Uncaught TypeError: mysqli_fetch_fields(): Argument #1 ($result) must be of type mysqli_result, bool given in /config/www/v1/webassist/mysqli/rsobj.php:260
3) Checked rsobj.php line 260. It is:
$this->Columns = mysqli_fetch_fields($query);
4) Did some research and found the following recommendation:
In PHP 8.1.19, there is no mysqli_fetch_fields() function available. Instead, you should use the mysqli_fetch_field_direct() function to retrieve information about the columns in a result set.
Would rather not start modifying your component - I'm sure you are aware of this issue. Is there a work around or should I downgrade the version of php until you can produce a fix?
It looks like mysqli_fetch_fields() should be available. The error you are getting implies there is an issue with your connection. If you give me FTP access then I can debug it for you, but I think the issue is with your database connection being wrong.
