Upload problems
Thread began 9/23/2009 11:23 am by info269075 | Last modified 9/23/2009 4:38 pm by anonymous | 1047 views | 3 replies |
info269075
Upload problems
Ok i may say i tried 10 times on 10 differents web sites I never succeed to make working the irite image upload. I don't undestand why there is always a problem on local or remote server. The path are never good. I tried once more and the problems goes on again, maybe some one could tell me what's wrong. I'm on a local sever, i'm working on a back office so i use an absolut path this if my config:
$Config['Enabled'] = true ;
$Config['UserFilesPath'] = 'C:/wamp/www/website/imgs/' ;
$Config['UserFilesAbsolutePath'] = 'C:/wamp/www/website/imgs/' ;
when i open the editor i can create a new directory inside the imgs folder but if i try to upload an image it always says "invalid file", it's just a jpg !
I'm really tired of this pluggin, but if someone understand what's wrong
thanks
anonymous
Hi there,
A couple of things look out of place.
First,
This attribute is not an absolute path but rather it needs to be set relative to the document root... so if your site is in the "website" folder, this setting should look like this:
$Config['UserFilesPath'] = '/imgs/' ;
The second - which you can fill if you prefer to specify the absolute path - is not always necessary... in fact, I would leave it blank like this:
$Config['UserFilesAbsolutePath'] = '' ;
Then, make sure you have the permissions set on the folder "imgs". Even if it is on a testing server, you will have to be sure to CHMOD probably to 755 at least - maybe even 777.
Once you do that, you should be good to go.
Best regards,
Brian
info269075
thanks
In fact it works like this - I'm on a local server.
/website/imgs/
But I still have a weird problem, if i put an image in the folder, i can see it in the Irite window, but when i try to ulpoad it says " invalid file", with gif, bitmap, jpg...
i'm on windows vista.
thanks
anonymous
Ok... glad you got the folder issue worked out... for the other problem, my next question is are you running PHP on IIS Server or Apache? It still sounds like there is a permissions problem on your folder.
Best regards,
Brian
