Google Maps hides Menue
A Google Map hides the dropdown part of a menu, and ignores z- index.
I once found a solution in the knowledgebase. Unfortunately there is no search function on the webassist page (or it is hidden very carefully)
When setting z-index, make sure you are setting the position as well. z-index does not work without setting the position.
Also try setting your wmode to transparant like this:
<param name="wmode" value="transparent" />
I'm not sure what you mean by searching the knowledgebase, but there is a search on the forum. It is located near the top of the forum in the forum menus.
