Unable to Activate Sculptor 3
Just purchased and unable to activate
We discovered a problem with our activation server this morning. We have fixed the problem and activation should now work properly. please attempt to activate again and let us know if you continue to have difficulties.
While executing onLoad in wacs_quickinsert.htm, the following JavaScript error(s) occurred:
At line 145 of file wacs_quickinsert.js:
ReferenceError: hasAutoSave is not defined
hi,
I have the same thing, impossible to make the Css scupltor 3.0 fonctionnal
i tried to delete the cache but nothing happens
Could you Help??
thanks
Sometimes you have to try deleting the cache file a couple of times.
try this, Go to Window -> Workspace Layouts -> Reset '<Name of your Workspace Layout>'
Then close Dreamweaver and delete the Dreamweaver cache file.
Restart the computer then try Dreamweaver once again.
