Nested repeat - set repeat filter based on parent results
Thread began 3/29/2022 7:39 am by Jared Lui | Last modified 3/30/2022 2:30 pm by Ray Borduin | 317 views | 4 replies |
Jared Lui
Please view this db fiddle: https://dbfiddle.uk/?rdbms=mysql_5.6&fiddle=e08a34fc3ee453fa6cb6f3ed0e2ae025 if needed.
I have a table called: users
> userID | userFirstname | userLastName
> 1 | John | Smith
> 2 | Alice | Jones
> 3 | Rob | Miller
> 4 | Ted | Kennedy
> 5 | Marty | Knight
A table called: eventDetails
> eventID | eventTitle | startDate | endDate
> 1 | Event A | 2022-03-27 | 2022-03-28
> 2 | Event B | 2022-03-27 | 2022-03-31
> 3 | Event C | 2022-03-29 | 2022-03-29
And a table called: eventPersonnel
> eventID | userID
> 1 | 1
> 1 | 3
> 1 | 2
> 2 | 4
> 2 | 5
> 3 | 2
> 3 | 4
I need to return all of the events for the logged in user where the events are within the current date. In the example DB I return 2 rows (eventID's 2 and 3).
I have these repeating correctly.
> -- This is my parent query. My actual WHERE statement uses a $_SESSION userID
> -- This needs to repeat for each event this sessions userID has within this time period
> SELECT *
> FROM eventDetails ed, eventPersonnel ep
> WHERE ep.userID = 4
> AND ed.eventID = ep.eventID
> AND CURDATE() BETWEEN ed.startDate AND ed.endDate
> <pre>
> eventID | eventTitle | startDate | endDate | eventID | userID
> 2 | Event B | 2022-03-27 | 2022-03-31 | 2 | 4
> 3 | Event C | 2022-03-29 | 2022-03-29 | 3 | 4
I also need to return all of the other users that belong to each of the returned event rows. So basically need to repeat the results of this SELECT statement within the repeat above.
> -- This is the child query.
> -- need to next repeat all rows of users for each of the returned events in the parent repeat
> -- The desired results should repeat the rows WHERE the eventID = the eventID from the repeating parent
> SELECT userFirstName, userLastName
> FROM users u
> JOIN eventPersonnel ep ON ep.userID = u.userID
> WHERE ep.eventID = 2
> <pre>
> userFirstName | userLastName
> Ted | Kennedy
> Marty | Knight
Results should look like this (omitted some columns for clarity):
Event B - 3/27/2022 - 3/31/2022
Ted Kennedy
Marty Knight
Event C - 3/29/2022 - 3/29/2022
Alice Jones
Ted Kennedy
The attached screenshot shows the output as it works now.
The code below works as it should. However I have the eventID in the WHERE clause hard coded to make sure it does work for testing. But of course it repeats the same rows for both event. I don't know how to code it so that the WHERE eventID = (the returned eventID from the parent repeat). Im sure that it's some parameter in PHP that needs to be declared or something. It's been several years since I've done this and don't recall how. I've also tried several version of JOINS, UNIONS and GROUP BY. Perhaps there's something new in MySQLi that handles this now?
$wa_repeatfor = -1; // Repeat Selection 1
if (!isset($wa_repeatcount)) $wa_repeatcount = 0;
while (!$currentEvents->atEnd() && $wa_repeatfor != 0) {
$wa_repeatfor--;
$wa_repeatcount++;
if (!$currentEvents->atEnd()) {
<dl>
<dt><?php echo(($currentEvents->getColumnVal("start"))?date('n/d/Y',strtotime($currentEvents->getColumnVal("start"))):''); ?> - <?php echo(($currentEvents->getColumnVal("end"))?date('n/d/Y',strtotime($currentEvents->getColumnVal("end"))):''); ?></dt>
<dd><h4><?php echo($currentEvents->getColumnVal("title")); ?></h4>
<h5><?php echo($currentEvents->getColumnVal("description")); ?></h5></dd>
<dd><?php echo($currentEvents->getColumnVal("location")); ?> - <?php echo($currentEvents->getColumnVal("client")); ?></dd>
</dl>
<!--PERSONNEL REPEAT START-->
$rsPersonnel = new WA_MySQLi_RS("rsPersonnel",$stapleton,0);
$rsPersonnel->setQuery("SELECT u.UserFirstName FROM users u JOIN eventPersonnel ep ON ep.userID = u.UserID WHERE eventID = 27");
$rsPersonnel->execute();
$wa_startindex = 0;
while(!$rsPersonnel->atEnd()) {
$wa_startindex = $rsPersonnel->Index;
<dd><?php echo($rsPersonnel->getColumnVal("UserFirstName")); ?></dd>
$rsPersonnel->moveNext();
$rsPersonnel->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
<!--PERSONNEL REPEAT END-->
if ($wa_repeatfor != 0) $currentEvents->moveNext(); // Repeat Alternate 1
} else {
} // End Repeat Alternate 1
if (!isset($wa_startindex)) $currentEvents->moveFirst(); // End Repeat Selection 1
Thanks in advance for any help!
Copy and paste your participants recordset inside the repeat region for the events. Then you can filter it based on the row from the events table and it will be re-created for each row and have the corresponding events.
Jared Lui
  - you can filter it based on the row from the events table
I Know this is wrong but it does pass code, just does not filter by the eventID of that event. It works if I hard code it. So how do I format this or am I way off?
$wa_repeatfor--;
$wa_repeatcount++;
$rsPersonnel->setQuery("SELECT u.UserFirstName FROM users u JOIN eventPersonnel ep ON ep.userID = u.UserID WHERE eventID = $currentEvents->getColumnVal(eventID) ");
$rsPersonnel->setQuery("SELECT u.UserFirstName FROM users u JOIN eventPersonnel ep ON ep.userID = u.UserID WHERE eventID = ".$currentEvents->getColumnVal("eventID") ."");
Just call me using the number at the bottom of every webassist.com page and we can set up a screen sharing session if you want to get a premier support ticket.
Jared Lui
Thanks Ray!
I'll get some questions together soon and set up a support ticket.
