Validating User Age with Redirect and set lockout Session Variable
Thread began 9/21/2009 5:32 pm by Kevin373660 | Last modified 9/23/2009 6:18 pm by Jason Byrnes | 3544 views | 8 replies |
Kevin373660
In a parent registraion php page using Validation Toolkit, I have a form with user input fields validated and a dop down menu/list with ages. I need to Validate a User Age and if a user is below a certain age, Redirect them to a page that says "sorry please ask your parents to set up your account" and set lockout Session Variable.
Would it be possible to set the Server Behavior Validation to redirect if the value for that one input/drop down is = say 0? And have a second Server Behavior on the same page and same form for the remainder of the input values?
Or is it better to have three pages: 1st with age, a 2nd with parent form and a 3rd saying your too young and sets a session lockout variable some how?
What is the best approach for a Rookie to set up?
Kevin373660
Ok, I did was able to acomplish the first step.
From one form (same page) I added a second WA Server Validation behavior using the Validation Type: Restrict Content and added a Failed Redirect to the 'too young' page.
Now I need to how to handle the lock out with a session variable.
On the to young page, create a session variable:
use the Cookies toolkit Set Session Value Server behavior. On the Server behaviors panel, Click the Plus Button and select WA Cookies -> Set Session value.
Use the Before Page Load trigger, set the name to "lockout" and the value to "yes"
Then using the SecurityAssist access rules manager, Create a new rule. Go to Modify -> SecurityAssist -> Access Rules manager.
Set the Restrict option. Click the Lightning bolt next to value and select the lockout session variable. Select Equals for the comparison and type "yes" in the compare to box.
open the page you wish to restrict access to and Click the Plus button on the server behaviors panel, Select SecurityAssist -> Page Access. from the list select the rule you just created and select a page to redirect to.
Kevin373660
Thank you, Jason. Your detailed instructions were very easy to follow.
However, I seem to have gone amiss somewhere. When I land on the parents_Registration.php, I am automatically redirected to the registration.php (with the “Please ask you parents to sign up your membership.”
The message in the url seems to indicate that it is checking the HelperGroupsRulesPHP file ok. But, I am not sure how it knows that the session is locked out since that variable should not be picked up until you hit the registration.php page. I have tried clearing the browser cash, closing and opening it again while testing. Where did I go wrong?
if("" == "") {
$_SESSION["userMinAge"] = "yes";
Registration.php
<?php require_once("../../WA_SecurityAssist/Helper_PHP.php" );
if (!WA_Auth_RulePasses("MinAgeLockout")){
WA_Auth_RestrictAccess("Registration.php");
IN URL
Registration.php?accesscheck=%2Fpages%2Fmenu%2Fparents_Registration.php
looks like you added the MinAgeLockout page restriction to parents registration page as well.
Kevin373660
Help, I am totally lost and have become very good at locking out the wrong pages. I have reread the docs and watched the online video twice. I have even tried reversing the code blocks between the two pages. Perhaps I am just not geting the logic of the process?
I want all visitors to be able to get to the parents_Registration.php, and only be locked out and redirected to the Registration.php, only if they are too young.
Please send your pages in a zip file so I can examine the coded.
Kevin373660
Thanks Jason. Please find attached a zip with both files. Setting up the Access manager for the whole site is my next step before eCart. So getting a handle on this will hopefuly be a big help.
I have created a support ticket so I can look into this with you a bit more.
