Bad coding
Thread began 8/21/2021 10:12 am by birdscreen398247 | Last modified 8/21/2021 4:54 pm by Ray Borduin | 191 views | 2 replies |
birdscreen398247
Bad coding
FYI: When I use SecurityAssist to secure a page, the program is inserting the following:
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
Note the double quotes...
This causes the "Dynamically-related files not found" error.
When I replace them with single quotes, the problem goes away.
Just a heads up...
I've never seen that before. Single and double quotes are usually interchangeable in php. I guess Adobe has an issue with recognizing them. What version of Dreamweaver are you using? This would appear to be a Dreamweaver issue that Adobe would address. I don't use dynamically related files because it can really slow down Dreamweaver, but I'll take a look and see if we need to change it.
birdscreen398247
I may have jumped the gun on that one.
I had some other files with the same issue (dynamically...), but changing the quotes did nothing.
So, it may have just been coincidental.
Sorry.
