the results page is set to show 10 records but only shows 1.
Thread began 5/19/2021 9:47 am by BjB | Last modified 5/21/2021 12:56 pm by Ray Borduin | 257 views | 4 replies |
BjB
My versions are Dreamweaver CS6, Dreamweaver 2020 and Data Bridge 2.3.5
I've tried to create a simple results page, insert page, update page, and search page using "Data assist pages" but in both versions of Dreamweaver the results page only show one record even though they are set to 10 or 20 records. This is happening when I navigate directly to the results page and when I search the results page.
It looks like this would show 10 rows. If you give me FTP access and a URL where I can reproduce the issue then I can figure out what is going on, but the code looks correct to me.
BjB
You have this right below the <body> tag:
mysql_free_result($WADApackmoreimages);
That should be at the very bottom of the page.
BjB
That was the problem, it was at the top and the bottom.
FYI, I didn't change any of the code after "Data Assist Pages" generated the code.
Thanks for your help
