I figured out the select multiple to simple select but still need to know how to adjust the validations ie change from required to not required or not required?
Site, page url, FTP are in the private message and I have attach a copy of the page.
The easiest way to do validation is to apply the Webassist->forms->validation->JQuery Validation command and then you just have to add "required" to and field you want required like: <input required ...
