data update
Thread began 1/21/2021 4:44 am by Jeff | Last modified 1/21/2021 1:49 pm by Ray Borduin | 163 views | 3 replies |
Jeff
data update
Hi Ray
I'm having trouble updating/editing and deleting data on the database using bootstrap 4.5 modals.
On the local server this is the error: "Notice: Undefined index: User_ID in C:\xampp\htdocs\nyumbasaccos\members.php on line 61"
link to the page: http://portal.nyumbasaccos.co.tz/members.php
It looks like you aren't passing the User_ID in the url when you update.
Instead you have it in a posted field.
You could probably just move the recordset code below the update code and fix the issue that way, since you redirect after update and the update code doesn't refer to the recordset.
Another way you can fix that by adding this line above the recordset (on line 57)
if (isset($_POST["WADAUpdateRecordID"])) $_GET['User_ID'] = $_POST["WADAUpdateRecordID"];
That way the User_ID parameter would be available, but really just moving it below makes the most sense because the code is more efficient. No need to create a recordset you aren't using.
Jeff
data update
Hi Ray,
I have tried to do what you have asked but im still getting the same error. I have attached the file so you can see what I have done
members.php
You should be linking to the page with something like:
http://portal.nyumbasaccos.co.tz/members.php?User_ID=1
To specify the ID of the user that you want to update.
