INSERT fails with no message
Trying to do a single column INSERT to test and the page just reloads, with no errors - and no INSERT actually happens. vardump shows the following:
object(WA_MySQLi_Query)#2 (37) { ["Action"]=> string(6) "insert" ["UseAction"]=> string(6) "insert" ["AffectedRows"]=> int(1) ["Connection"]=> object(mysqli)#1 (19) { ["affected_rows"]=> int(-1) ["client_info"]=> string(79) "mysqlnd 5.0.11-dev - 20120503 - $Id: 15d5c781cfcad91193dceae1d2cdd127674ddb3e $" ["client_version"]=> int(50011) ["connect_errno"]=> int(0) ["connect_error"]=> NULL ["errno"]=> int(0) ["error"]=> string(0) "" ["error_list"]=> array(0) { } ["field_count"]=> int(0) ["host_info"]=> string(38) "someserver.com via TCP/IP" ["info"]=> NULL ["insert_id"]=> int(1555) ["server_info"]=> string(15) "5.6.50-90.0-log" ["server_version"]=> int(50650) ["stat"]=> string(155) "Uptime: 1004242 Threads: 24 Questions: 421360578 Slow queries: 175 Opens: 14419023 Flush tables: 1 Open tables: 2000 Queries per second avg: 419.580" ["sqlstate"]=> string(5) "00000" ["protocol_version"]=> int(10) ["thread_id"]=> int(5322026) ["warning_count"]=> int(1) } ["Debug"]=> bool(true) ["EncryptionAlgorithm"]=> string(8) "blowfish" ["EncryptionKey"]=> string(9) "Change Me" ["EncryptionMode"]=> string(3) "cbc" ["Error"]=> string(0) "" ["ErrorMessage"]=> string(37) "There is an error in your SQL syntax." ["ErrorNo"]=> int(0) ["FieldCount"]=> int(0) ["Filter"]=> string(0) "" ["FilterValues"]=> array(0) { } ["ID"]=> int(1) ["InsertID"]=> int(1555) ["JavascriptRedirect"]=> bool(false) ["MRTField"]=> string(3) "mrt" ["NumRows"]=> int(0) ["ParamColumns"]=> array(1) { [0]=> array(2) { [0]=> string(5) "Fname" [1]=> bool(false) } } ["ParamCount"]=> int(1) ["ParamDefaults"]=> array(1) { [0]=> string(10) "WA_DEFAULT" } ["ParamTypes"]=> array(1) { [0]=> string(1) "s" } ["ParamValues"]=> array(1) { [0]=> string(3) "afd" } ["Prepared"]=> bool(true) ["RelationalColumns"]=> array(0) { } ["RelationalKeyColumn"]=> bool(false) ["RelationalRows"]=> array(0) { } ["RelationalRowsFound"]=> bool(false) ["RepeatConditions"]=> array(0) { } ["RepeatedParams"]=> array(0) { } ["RepeatIndex"]=> int(2) ["SelectedResult"]=> bool(false) ["Salt"]=> bool(false) ["SaveAs"]=> string(0) "" ["Statement"]=> string(41) "INSERT INTO blah_1 (`Fname`) VALUES (?)" ["Table"]=> string(8) "quotes_1" }
What's going on? Thanks
