Audience qry issue
Thread begun 11/30/2020 4:51 pm by Gizza372666 | Last modified 12/01/2020 8:47 am by Ray Borduin | 585 views | 1 replies |
Gizza372666
Audience qry issue
Hi Ray,
Thanks for getting back!
Just found the instructions on how to do this. Visit:
https://stackoverflow.com/questions/23921117/disable-only-full-group-by
Scroll down to the last screenshot.
The solution is there (I hope this will help others too).
There is sql error when I try to check the audience.
SELECT SentDateTime AS EntryDateTime, COUNT( SentDateTime )AS EntryCount, HOUR( SentDateTime ) AS Hours FROM pm1_mailing_audience_members WHERE MailingID = ? AND SentDateTime IS NOT NULL AND SentDateTime <> '0000-00-00 00:00:00' GROUP BY YEAR( SentDateTime ), MONTH( SentDateTime ), DAY( SentDateTime ), HOUR( SentDateTime ) ORDER BY SentDateTime
Expression #1 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'mdsrtrt5_yia2.pm1_mailing_audience_members.SentDatetime' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by
The issue is that you are referring to the column SentDateTime individually and in aggregated columns in the group by and count functions.
You may be able to simply turn off sql_mode=only_full_group_by in your server since you are on a dedicated host to resolve this issue. Otherwise you might have to restructure your SQL statement and possibly break it into separate SELECT statements to get the data you want efficiently.
I couldn't get in with the FTP information provided, so I couldn't look at the page directly.
