Maps on all pages are no longer working
Thread begun 11/26/2020 9:34 am by warrioruk | Last modified 11/30/2020 8:55 am by Ray Borduin | 505 views | 1 replies |
warrioruk
I've been using pro-Maps for some time, very recently they (many websites) all appear to have stopped working.
I've got a valid API key & enabled the Geocoding & the Geolocation API's
(examples)
https://www.theisrm.com/locations_test.php
https://www.abrassett.com/2799-Dartmouth-appliance-repairs.php4
I've just downloaded the Pro maps 107.mxp and installed it, that's the most recent I can get. BTW it defaults to http:// and doesn't use https for the google link + it uses v=2 (which I tried & I have also tried v=3
Is there a fix?
Google changed the default permissions, so you may have to go into the google api manager and make sure the correct api services are enabled for maps to work properly. I think the code on your page is fine, but the google settings need to be updated.
You will have to enable maps and geocoding apis and probably put in billing information on the google site for the api key you are using.
