Cannot use form builder at all
I delete it and reinstall and when i use the insert for i get the error:
Hi
I had exactly the same problem. Managed to get it to finally work by deleting the "WinFileCache.dat" file located in the following folder "Adobe/Dreamweaver/en_US/Configuration/"
Follow the following link for full details.
The extension works fine following this fix.
Regards
Dave
