Is it possible to use two authentications on a restricted page
Thread began 9/14/2020 11:37 am by illbe322016 | Last modified 9/14/2020 1:55 pm by Ray Borduin | 73 views | 3 replies |
illbe322016
I have a login/authentication for admin pages and one for user pages. I would like the admins to be able to link to and see the user pages without a separate login for them. I tried adding two values to the $RestrictAccess->Name = "LoggedIn"; value for example $RestrictAccess->Name = "LoggedIn, LoggedInFBO"; to no avail. Can you please tell me if this is possible and how I need to change the code if it is.
Thank you in advance
Tom
You can use:
if (!WA_MySQLi_Auth_Check(array("LoggedIn","LoggedInFBO"))){
WA_Auth_RestrictAccess("sorryAdmin.php");
illbe322016
Just a little more help
Here is the code block I'm using from the MSQLi behaviors, I'm not sure how to modify this using the code you sent, can you help?
if (true) {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "LoggedInFBO";
$RestricAccessRedirect = "sorryAdmin.php";
if (function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
Sorry for the stupid question.
T
Remove that code and use the code I gave above in its place.
