HTML Editor on a different URL for CMS. Images created in html editor show relative path and thus do not show on site
Thread began 8/25/2020 5:58 am by Shingisai | Last modified 8/25/2020 8:55 am by Ray Borduin | 153 views | 1 replies |
Shingisai
We are using the html editor to create blog articles. This is done on a cms that we created. When we upload an image into an article using the Full Managed HTML editor it stores the relative URL. On the actual website, we cannot see the images as they are pointing to the relative URL not the absolute URL. How do we fix this
Also how do we set the startup folder when someone clicks the browse server button
Kind Regards
Kind Regards
The HTML editor should use the root relative path, so something must be wrong in the settings if it uses a file relative path.
The startup folder can be set in the config file, or you can set a session variable with: $_SESSION['WA_UserUploadFolder']
