extension management
Thread began 8/05/2020 1:45 am by software.current355386 | Last modified 8/05/2020 1:09 pm by Ray Borduin | 155 views | 5 replies |
how can you telll what version is installed
What version of which program?
when I updated the origin question I must heave Donne it wrong so I will redo it
CC2019 running on iMac Pro
dmxzone
not accessed DW for some time but long enough to forget can you hep please
how do you check the version of extension loaded , update ,de ét if need be, and extension
can I upload overwriting exiting or would it be better to edeletet installed version fit=st
would you clear out the cache file beforehand
Just install the latest version. You shouldn't have to uninstall previous versions of the same extension, but it wouldn't hurt either.
The version should be listed in the extension manager, but I'd just reinstall anyway to be sure.
any other extension manager u recommend thats compatible with iMac Pro and running Catalina
DMX Zone and Project Seven seem to have the most reliable ones.
