Class eCart Repeat Region
Thread began 7/08/2020 8:53 am by Daniel | Last modified 7/08/2020 11:45 am by Ray Borduin | 696 views | 4 replies |
Daniel
Good Morning,
how are you?
1. How do I put an outside(the array is created outside the class) array inside a Class?
I create the array but it doesn't read or display it when I want to print it out through a method in a Class.
Because what I want to do is that the products have different pickup addresses and the delivery address is only one address so I'm using the
ecart repeat region to get that information and then create a array and then work out the one or more quotes depending on the amount of pickup
addresses for the ecart transaction. I'm using my own integrated Courier Service.
2. Where do I change the SESSION value for the eCart session the way I want it to be?
Thank you for your help.
You could declare the array as global in the class, or save it in the $GLOABALS object to be able to access it from within the class.
See: https://www.php.net/manual/en/reserved.variables.globals.php
and: https://www.php.net/manual/en/language.variables.scope.php
That should help you understand how variable scoping works in php so you can access data from different locations.
Daniel
Thank you very MUCH I appreciate your help.
Daniel
What is wrong with my code?
$array = array();
while (!$ThankYouJesus->EOF()) {
$array[] = $ThankYouJesus->DisplayInfo("ID");
$ThankYouJesus->MoveNext();
$ThankYouJesus->MoveFirst();
$GLOBALS[$array];
print_r($array);
class DankieJesus {
function FreeInChrist() {
print_r($array);
$new = new DankieJesus();
$new->FreeInChrist();
Daniel
Hallelujah! Dont worry I got it:
$array = array();
$GLOBALS['hope'] = $array;
print_r($GLOBALS['hope']);
class DankieJesus {
