Unknown column 'ColumnName' in 'order clause'
Thread began 9/18/2009 12:20 pm by kphillips162496 | Last modified 7/27/2011 12:26 pm by wbrooks199805 | 4935 views | 13 replies |
kphillips162496
I seem to be missing something in creating linked headers for sorting. After following the Sorting by Column Links directions (Started over 4 times with different errors) I have come to adding one column to sort (keeping it as simple as possible to track down the error) and I am at a point where I have Listing Price as a sort link on the header, but am getting the error
Unknown column 'WADALAHomes.MLS' in 'order clause'
When I remove the Sort and Binding and clean up what is left behind when you remove these, it works just fine. So I'm baffled why this won't work, no matter what I try, in the end it is the same error. The MLS column.
Has anyone else run into this, I did check the forums, but haven't found it.
Thank you to anyone that can enlighten me. :)
The Tutorial for creating the links has you create a query string variable named sort and set the value to the name of the column.
for example, if the recordset has a column named "userName" that you wish to sort by, the link would be:
myPage.asp?sort=userName
from the error massage, you are creating the querystring variable with the value WADALAHomes.MLS which is not a column that exists in your recordset.
kphillips162496
Actually all of the fields in this results page are WADALAHomes (the Recordset name) DOT Field name. And MLS is one of the columns. I do have a link created on the MLS field to the details page and took that off to see if it made a difference, but nope, same error.
The only sort that was setup was for List Price though.
send a copy of your page in a zip file so I can look at the code.
kphillips162496
Found it...sorry
LAHomes_Results.zip
I dont see how the code on this page could generate that error, the sort link you have is correct:
<a href="LAHomes_Results.php?sort=ListPrice">ListPrice</a>
try changing the following code:
$WADALAHomes = mysql_query($query_limit_WADALAHomes, $MLSDatabase) or die(mysql_error());
$WADALAHomes = mysql_query($query_limit_WADALAHomes, $MLSDatabase) or die($query_limit_WADALAHomes);
and post back the SQL
kphillips162496
You are brilliant!!
Thank You!! I have been fighting this thing for over a week!! You are brilliant. I will save my next issue for another day. Thank you so very very much.
Miguel
im having the exact same issue and did the change to the query and worked fine, just in case im trying out the DataAssist 2.0.7 277 (Beta) before on version 2.0.6 i never had this problem with sort of fields
can you give some more details please?
You say you edited the query, can you give some details on how you edited the query, what was changed?
can you send a copy of your page?
wbrooks199805
having the same issue
I tried this fix but didn't work. I have attached the file.
subscriber_Results.php.zip
