Display current row recordset number
Hi how can I display current row record number?
<?php echo($Recordset->Index + 1); ?>
That might be what you need. That is the current index in the results returned. However, you would usually use the actual AutoNumber primary key of the table to display a record id since it is permanent and the index in the result set might change as records are inserted or deleted.
