How to control placement of a checkbox?
Thread began 9/18/2009 12:59 am by steve387748 | Last modified 9/21/2009 3:31 pm by tom92909 | 2505 views | 10 replies |
steve387748
How to control placement of a checkbox? - RESOLVED
I have a checkbox that a user must click to accept our terms when they submit a signup form. How do I put the checkbox on the left rather than the right?
One last question, I'd like to define what the terms are as a bulleted list under the checkbox and its label (which reads "I agree that:")?
Something like this:
checkbox - I agree that:
I accept the User agreement and privacy policy (note that this is a link to the file)
I am at least 18 years old.
I may receive communications from XYZ related to my membership.
I figured out how to enforce the checkbox was clicked or it won't submit, but wondering what will happen if I add the custom code after the checkbox and whether this code will be wiped out if I edit the form using FB again.
tom92909Beta Tester
Maybe this will help?
html:
<table>
<tr>
<td valign="top"><input name="" type="checkbox" value="" /></td>
<td></td>
<td>I agree that:<br />
I accept the User agreement and privacy policy (note that this is a link to the file)<br />
I am at least 18 years old.<br />
I may receive communications from XYZ related to my membership.</td>
</tr>
</table>
if you create the checkbox on a new line, it will automatically be shifted to the left.
to add the bulleted list, use:
<ul>
<li>I accept the User agreement and privacy policy (note that this is a link to the file)</li>
<li>I am at least 18 years old.</li>
<li>I may receive communications from XYZ related to my membership.</li>
</ul>
Yes, the custom code will be wiped out if you edit the Form contents.
steve387748
When you say create the checkbox on a new line, are you meaning while in the Edit Form tool of FB? Currently the checkbox shows as being on its own line with nothing else. I think the format is something like:
Line 1
Set 1
I agree that: checkbox (validation is on)
Is it perhaps somewhere else I should be looking to force the checkbox to the left?
steve
steve387748
Regarding losing a bullet list of info if editing the form manually and then re-entering FB for the form, what do you recommend on this? Just make sure I have it as close as can be using FB and add code by hand when I think it's finished? It isn't like I'd have to retype a bunch of text even if I did want to edit the form again I suppose.
Even if I was to remove the bullet list, I'd still like to have a link to the T & Cs for the company when a person signs up for the service.
So the checkbox and statement would look like:
Checkbox "I agree with the terms and conditions" and have "terms and conditions be a link to the page that contains the T&Cs.
So it sounds like what you are saying is that if it can't be done through the FB current interface, it will be hand coding on my part with the knowledge that if I ever make changes to the form using FB, I'll have to go back and do the hand coding again?
steve
steve387748
By the way, I noticed that the checkbox is aligned like every other input field in the form so that appears to be the reason it is to the right of the label. Any way to change this so it will be to the left. I have the "I agree that:" checkbox, the Captcha, and the security question all in their own fieldset if that makes a difference.
steve
Originally Said By: steve387748
Line 1
Set 1
steve
steve387748
Thanks for your suggestion Tom. I have a feeling the alignment has to do with the way FB is designed to add a line and set. Note too that FB is using divs and no table controls for layout. I'll get the hang of this tool yet :o)
thanks again,
steve
Originally Said By: tom92909
html:
<table>
<tr>
<td></td>
</tr>
</table>
tom92909Beta Tester
My pleasure!
steve387748
Out of curiosity Tom, you show an example using a table for the layout of the form, does this mean you aren't using FB to create the form and are just using a table layout (since FB uses divs), or are you using FB with a form that's been created with a table layout? If so, how are you using FB when having a form in a table?
steve
Steve,
Sorry, I misunderstood the question the first time I read it. I though you where asking how to get the Checkbox to the left of the pager, not the left of the label.
The Form builder interface doesn't allow you to place the labels to the right of the elements.
You will need to rearrange the label and form divs after the form has been created.
If you edit the form using the form builder interface later, the c changes will lost.
