Errors after upgrading
Thread began 9/17/2009 9:28 pm by noahm26385458 | Last modified 9/18/2009 8:49 am by Jason Byrnes | 1635 views | 1 replies |
noahm26385458
I upgraded CSS Sculptor, CSS Menu Writer, and SiteAssistPro to the newest versions. I went to use my Site Import and got the following error:
I click on File>Site Import... and the WebAssist Site Tools box appears. There is nothing in the drop down menu to select. I click on Go and get this error message:
While executing onClick in WA_SiteTools_Progress.htm, the following JavaScript error(s) occurred:
In file "WA_SiteTools_Progress": ImportNew is not defined.
Then I found I had an error with SiteAssistPro as well.
I uninstalled everything and reinstalled Site Import and get the same error.
I am using Dreamweaver CS4 on Mac OS 10.5.8 PowerPC
Edit-----------------------------------------------------------------------
I found the location of the file: MacFileCache in one of these posts and deleted it. Site Import worked. I will now have to reinstall everything else. You should put the location of these files we need to delete in the support docs. I searched my computer and it didn't show up. Apparently the file adds some random numbers to the end of its name.
See the following for detailed instructions:
