MySQLi error: 1064
I'm getting this error on a fresh install of macOS 10.14.6 and Dreamweaver CS6. I haven't/can't publish the new site because of this. Why am I getting this error and how do I fix this?
When do you get this error? What did you click? It looks like you may have a dash in a column name? That might be the source of the problem.
Yup... the dash in the column name was causing the error (fickle). When I removed the dash, the form worked fine. Thanks for pointing this out.
