Login Page fails to load
Thread began 9/17/2009 10:20 pm by Peterson Design Studio - jefferis | Last modified 9/18/2009 3:10 pm by Peterson Design Studio - jefferis | 1192 views | 2 replies |
Unless I remove user authentication behaviors from the page.
I used a wizard to create a login page but the page becomes blank if I don't remove the user authentications. But if I remove them, then I cannot seem to log in...
admin/
Is the wizard applying the authentication behavior inappropriately to the login page?
if (!isset($_SESSION)) {
session_start();
?><?php virtual('/Connections/LiveGold.php');?>
<?php virtual( "/WA_SecurityAssist/Helper_PHP.php" ); ?><?php
if ((((isset($_POST["autologinoption"]))?$_POST["autologinoption"]:"") != "")) {
setcookie("AutoLoginPWD", "".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") ."", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("AutoLoginUN", "".((isset($_POST["username"]))?$_POST["username"]:"") ."", time()+(60*60*24*30), "/", "", 0);
?><?php
if ((((isset($_POST["remembermeoption"]))?$_POST["remembermeoption"]:"") != "")) {
setcookie("RememberMePWD", "".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") ."", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("RememberMeUN", "".((isset($_POST["username"]))?$_POST["username"]:"") ."", time()+(60*60*24*30), "/", "", 0);
?><?php
if (isset($_POST["LogIn_x"]) && !isset($_POST["remembermeoption"])) {
setcookie("RememberMePWD", "", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("RememberMeUN", "", time()+(60*60*24*30), "/", "", 0);
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $LiveGold,
"database" => $database_LiveGold,
"tableName" => "myadmin",
"columns" => explode($WA_Auth_Separator,"username".$WA_Auth_Separator."password"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"username"),
"sessionNames" => explode($WA_Auth_Separator,"username"),
"successRedirect" => "myadmin_Profile.php",
"failRedirect" => "",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
if((((isset($_SESSION["username"]) && $_SESSION["username"] != "")?"LoggedIn":"") == "")&&(((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") != "")&&(((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") != "")){
"columnValues" => explode($WA_Auth_Separator,"".((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") ."".$WA_Auth_Separator."".((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") .""),
Most likely the problem is the uses of the virtual function for the include file:
This actually an issue with Dreamweaver. The Virtual function is only supported on some Apache servers.
Dreamweaver will use the virtual function if you set the "Create Links Relative To:" option that is on the Local Info tab of the site Definition to "Site". Before running the Security Assist wizard, you should change that to "Document" so that Dreamweaver will use the require_once function instead.
Okay, that's weird. My server, BTW, is FreeBSD. I ended up doing the login in ADDT because I couldn't figure out what was wrong, but every page was blanking out. I'll try that next time...
