MySQLi Insert Record - 'Dynamic Data' dialog box, my form is not listed. Cannot assign fields to columns.
Thread began 3/30/2020 9:40 am by p.kelembeck232519 | Last modified 3/30/2020 12:18 pm by Ray Borduin | 851 views | 4 replies |
p.kelembeck232519
Dreamweaver CS5
Hi Support
I have created a form to insert a new record. When following the instructions to assign form fields to database columns my forms does not show in the 'Dynamic Data' dialog box. Please see attachment showing what I get in the dialog box.
Please let me know how it can be fixed or worked around.
Also if I am having this issue with inserting a record, does this mean I am going to have further issues when creating an update a record form?
Regards
Patrick
support_request_01.pdf
Please attach the page you are working on so I can try to reproduce it. Maybe your form and form elements don't have name attributes?
p.kelembeck232519
See file attached.
Your form elements don't have names. Forms use the name attribute to submit the values. Without a name they are inaccessible to server side code.
This:
<input type="text" class="form-control text-center" id="title">
needs to be this:
<input type="text" class="form-control text-center" name="title" id="title">
Once you add names they will show up.
p.kelembeck232519
Hi Ray
Thanks for the fix. It working great now.
Regards
Patrick
