Pagination doesn't work
Can anybody help me mysqli pagination doesn't work with clen url's.
I am send everything in attachments.
Can I get FTP access? I'll debug this. It could have something to do with your .htaccess file.
Dear Ray FTP access is in Private message.
Your mod rewrite needs to be:
RewriteRule ^([A-Za-z0-9-]+)/?$ s.php?s=$1&p=$2 [NC,L,QSA]
instead of:
RewriteRule ^([A-Za-z0-9-]+)/?$ s.php?s=$1&p=$2 [NC,L]
The QSA at the end tells it to Query String Append and keep existing querystring values instead of stripping them off.
Dear Ray pagination works great but now i have another problem. When i apply Show If Not First page for previous link i am getting error (There is an error in your SQL syntax.) :(
Error is on page s.php - FTP is the same.
Thanks in advance
The recordset code got messed up. I think this was an issue in a previous build. Please reinstall the extension and that should fix the problem moving forward. Download the page for the working code in the meantime.
