Populating multiple fields from one dropdown-select
Thread began 3/01/2020 11:08 am by Paul | Last modified 3/02/2020 10:57 am by Ray Borduin | 194 views | 1 replies |
PaulBeta Tester
Using DA to build an insert page.
I have a drop down select populated by a recordset.
The recordset contains all records, with 4 associated fields.
On selection, the value populates the form field. As expected.
How do I populate the other 3 form fields with the other field-items returned from the recordset?
I don't know your database structure, but usually this is done by adding a recordset for each select list and populating the select list from that recordset.
